shovelheadrob wrote:Ford will be able to cut you a key from the reg no, you will need proof of ownership etc, but as Blue Estate says you won't know if the locks have ever been changed until you have paid for the new key!
Altransit wrote:Don't be shy, put his name up, someone else may be able to use his services
TriumphStag wrote:
Oh - one other thing he mentioned was that the key that I did have in the glovebox (that wouldn't start the van) was an original but that the chip was/is dead as his machine could not read it. I guess that is that and there is no way to "re-energise" it?
Yes, failed chip is failed....
however this key is a good candidate to hide under the van somewhere in case you lock your keys inside miles away from your spare set!
