ake wrote:This is why you should unlock the van with the key at least once a week
ake wrote:Your front battery is knackered, and opening the bonnet is a waste of time because the jump start point is connected to the start battery, not the aux battery
If you double clicked the lock button when you parked it up, then it is dead locked, so trying to open it from inside is also a waste of time.
keep trying the key in the door, and perhaps spray in some wd40. if that fails either call a lock smith, or break the quarter light window, put key in, turn on ignition, and then unlock door from inside.
happypatrol wrote:there is a way of doing it by giving a direct feed to the alternator and then use the remote to open the doors. but i wouldn't advise doing it if you don't know what you are doing. Ive done it on a ferrari f430 so I'm sure it would work on a transit. you basically give power to the system enough to open the doors. The you can charge your battery. But it would need to be done via a fused supply to avoid and mishaps and earth it somewhere good. If you have a booster pack or another battery its easy to do.
Hanna H wrote: They looked at it and said there are two batteries in transits (mines a 2007 model), one in the engine and one under the drivers seat which just controls the locking system. And that battery was dead! They replaced it (£140 for the battery and £100 for labour) and it works perfectly again. I'd not seen this information about the batteries anywhere when I'd looked online so now I've discovered it I'm just posting this message everywhere in the hope it'll help someone else! Such a relief it's fixed and I didn't have to dismantle anything else inside!
