hissing noise 2005 tddi
Postby motovanner » Sun Jul 20, 2014 9:15 pm
hi guys, 2005 2.0 tddi
wonder if anyone can help. had my van van tuner - ed. it pulls better than it did before esp when its empty in the back.
but, when its heavily laden going up hill, if i put down the passenger side window ( and especially if theres a wall or hedge running parallel to the road that reflects noise back ) from about 1800 revs up to 3000 theres a really loud hissing noise and a lack of power. its worse when the weather and the van are hot. in cold weather its still there but not quite as loud. ( im thinking warm weather is causing a rubber hose to "give" more, maybe a crack(s) opening up, when its cold the rubber is stiffer and stays closed /more air tight kinda thing? )
when the van was in the garage the mechanic said he checked all the hoses etc and everything was fine. but he was working onhis own - only revving the van standing in the garage in neutral.
it doesnt make the noise doing that.
it really needs to be put on a rolling road so the engine is under load and pulling hard around 2500 when the noise it at its loudest and then it can be identified as to where its coming from.
iv got it van tuner-ed but not really getting the benefit of it because of this. on motorways with a heavy load it struggles to keep up 60 on steep hills. and this hissing is very loud then.
what should i do? i need a garage with a rolling road that can test the engine under load with 2 mechanics - 1 holding the engine around 2500 rpm under load whilst the other one is under the hood - it would take a minute or less to find it because its so loud!.
would a ford garage have a rolling road or how do i sort this - its doin my nut in now!
Facebook/All tents Camping Group
motovanner
Re: hissing noise 2005 tddi
Postby ake » Sun Jul 20, 2014 9:33 pm
Check it all yourself, get some one to rev it while you check every hose, turbo, intercooler and inlet manifold for leaks
Inlet manifolds are known to crack
Postby motovanner » Sun Jul 20, 2014 11:02 pm
ake - this was the point i was Trying to make
it only does it when its under load - revving it in neutral does nothing. there is no hissing when its in neutral and revving at any revs.
so how do i check it myself with the engine under load?
motovanner
Postby celtic0125 » Sun Jul 20, 2014 11:18 pm
Put it on some axle stands lol
celtic0125
Postby 75psT330lwb » Sun Jul 20, 2014 11:39 pm
celtic0125 wrote:Put it on some axle stands lol
and do what :?: :roll:
Moondust Silver 125 TDCiT260. Lots of toys (The Flying Machine!)
75psT330lwb
Postby motovanner » Mon Jul 21, 2014 12:07 am
:roll: :roll: :roll: clueless
motovanner
Postby TripleSix » Mon Jul 21, 2014 12:45 am
You need to find the boost leak, its either the pipework, intercooler or inlet manifold.
making a pipework leak tester is a good start
http://youtu.be/atretf9u-Mc
2013 MWB AWD
TripleSix
Postby Altransit » Mon Jul 21, 2014 9:22 am
:idea: Check the pipe that runs from the EGR, and round the back to the manifold
Postby dymondaudio » Sat Jul 26, 2014 7:36 pm
I have exactly the same problem on my mk7 and it is driving me insane. It's been in to the garage and I've checked all the hoses - nothing. Exactly the same symptoms as yourself so if you find the leak on yours please share on here!
2008 2.4 T350/140 Trend LWB H/R
2008 2.4 T350/115 LWB HR
2006 2.4 T350/100 LX LWB MR
2002 2.0 T280/75 MWB MR
2000 2.5 SWB MR
dymondaudio
