@ transit_bandit
when you replaced your fuel timing solenoid
is there a secret on how to release more wire?
I'm going through my replacement right now but seem to have bugger all slack
it was barely enough to slide the solenoid out
of it's hole
the second hand one I have as a replacement came with some sort
of silver spring steel clip
is this somehow a retainer for the wiring?
I think I can spot the end
of the clip on the one still in the van but couldn't get it
of with a pair
of pliers
does anyone have an exploded view or pic that shows how this fits together?
I noticed on my existing fuel timing solenoid that the wires are bare (insulation gone)
which I guess means the solenoid was probably just fine but the wires shorting out produces the fault
another tip for those to attempt this
make sure you use a decent quality (solid) torx T30 spanner
I thought I had a half decent set
of L-shaped torx keys but the ones holding the solenoid in were pretty tight and I ended up buying a set you use on a 1/2 " socket set
