dieseldel wrote:hi
spigot bearing collapsed, good luck getting old one out !!
DrDeAtH wrote:Pack it with grease and tap a rod into the centre... It uses the grease to push the spigot bearing out. You will probably find a socket extension bar is the weapon of choice. Just wrap it in tape until it fits neatly into the bearing.
Pack more grease in as the bearing moves out of the crank.
Sam1274 wrote:Thanks for everyone's help the spigot had collapsed just have to get the old one out now
75psT330lwb wrote:i take it these are only fitted on 2.4s??
