If you've fitted a VP44 pump, I suspect wiring or wrong ECU
ECU with DCP806 on it is used on the 2.0 & 2.4 engines with VP30 pumps
Upgrading from 90ps to 125ps, then timing chain, both camshaft sprockets & crankshaft sprocket require changing.
