v8dave wrote:Module programming
You'll need a working "extended programming" patch to turn on the ids functions if it's not a genuine copy.
If there is a newer calibration than the v81 set for a pcm that old I'd be surprised. IDS should prompt with a file name of a new calibration if it knows of one.
You can get them from the motorcraft site motorcraft once you know what file name to ask for.
v8dave wrote:IDS will tell you the name of the file required.
If there is not an update then you will not get the name.
v8dave wrote:In that case I suspect you'll need to start ids and rather than let it get the id from the van you tell it the details manually.
It probably works like this :-
1) upload the existing module programming from the van as if you are going to change the modules.
2) change the ids settings to the power you want.
3) download the new settings to the van.
You might need a new or edited "as built" file for the van.
I'm sure an expert will come along and read this soon
Edit: has this been done to a Mondeo ever ? worth a google.
cyrus883 wrote:Mate ur a mine field of info thankyou for taking the time to answer back
paul2012 wrote:Once IDS has retrieved data from vehicle, it will only install the current PCM calibration if replacing PCM - downloads calibration from old module then installs it onto new one.
Or update calibration if one is available. - For example if your transit is a 75ps then it will only load the 75ps as confirmed via Vin number (which IDS will ask you to confirm)
Tip
You can fool IDS into thinking PCM is blank to install a different calibration.
Once you have done this IDS will ask for PCM part no or tear tag.
It will then check for calibration If not found on your IDS system. IDS will ask to check & download it from Motorcraft - internet connection will be required
If calibration is not available then "as built data" is requested to proceed
Requested info.
As Built Data for a 2003 2.4L TDDI 120/125ps RWD transit mk6 T350
2.4L TDDI 120/125ps PCM info
PCM Part No 3C11-12A650-GA
Tear tag 8CAA
Visteon DCP-806
cyrus883 wrote:
WOW mate thankyou for that I will try that I will let you know how I get on ur a star I love this forum
No problem m8
No problem m8
Hi mate still having troubles lol when I load ids it finds the ecu and asks me if it right I click no I put in the numbers you gave me and then comes back with 90ps still am I doing something wrong thanks again Steve ps I've checked all my wiring green white wire from pump to ecu and connected but still have codes p1608 p1665 and p0216 I'm starting to think the pump I got is fooked thanks Steve
