by wole » Sat Aug 30, 2014 10:19 am
hi all I have a05 plate mk6 2.4 tddi t115 rwd recovery truck the problem is the clutch pedal sometimes goes slack then when pressed again its ok. I have renewed the master and slave cylinders and it has a good pedal.i am wondering if it is anything to do with the dualmass clutch self adjusting mechanism. if this problem gets worse I am thinking of fitting a solid clutch. any suggestions welcome thanks dave
