loot34 wrote:140 doesn't like to be blanked, just clean the inlet once a year, remap is a must tho
blue estate wrote:Mines ok blanked and turned off
motorman116 wrote:blue estate wrote:Mines ok blanked and turned off
Oh my something that you haven't broken
Brains Mk6 transit wrote:When I blanked my mk6 the elbow into the inlet had a 4mm layer of the black gunk in the bottom 3 years later I removed the elbow and only a light coating of oil so it's worth blanking it off
Cal1990 wrote:Brains Mk6 transit wrote:When I blanked my mk6 the elbow into the inlet had a 4mm layer of the black gunk in the bottom 3 years later I removed the elbow and only a light coating of oil so it's worth blanking it off
Brian my vans a 05 where is EGR? Back of engine at right hand side if you reach round or is it at front ? Every photo I see is different :confused:
Brains Mk6 transit wrote:Cal1990 wrote:Brains Mk6 transit wrote:When I blanked my mk6 the elbow into the inlet had a 4mm layer of the black gunk in the bottom 3 years later I removed the elbow and only a light coating of oil so it's worth blanking it off
My vans only a 75 but the 25mm ribbed alloy pipe bolts to it and I think you right at the back going by cossies guide in the technical how too's
