Ford transit mk6 2005 cutting out
Postby Transit like me@daa » Mon Sep 01, 2014 9:30 am
Hi all
Hope you can shed some light for me
Got my mk6 serviced 2 days ago oil air
filter
I was driving to work today
And vans coil light ce on and van cut out
Restarted it and ran for another few miles then cut out
With coil light flashing
Any help would be appreciated
Transit like me@daa
Re: Ford transit mk6 2005 cutting out
Postby jay » Mon Sep 01, 2014 10:15 am
needs codes reading otherwise its pure guesswork..but take it back first as if its fine before service must be something they done
jay
Postby Transit like me@daa » Mon Sep 01, 2014 11:21 am
Hi mate cheers for reply
It was my self that serviced it
Used it nxt day no probs then today
Cut out and coil
Light on
Transit like me@daa
Postby Altransit » Mon Sep 01, 2014 12:33 pm
Look back over what you did in and around the engine bay, you may have disturbed a plug or damaged a wire to the pump. The pump loom in the area near to the starter motor is prone to getting damaged wires :idea:
Postby Transit like me@daa » Mon Sep 01, 2014 1:53 pm
Hi had a look around were I was working all seems good tryed all plugs connectors nothing loose
I didn't change fuel filter wen I done rest of stuff
Could that cause the issue ive been having
My freind said he had a transit connect do same thing
Cut out and flashing coil light
He thinks it could be injectors
Any thought on this greatly appreciate
Transit like me@daa
Postby Altransit » Mon Sep 01, 2014 1:58 pm
TDDi or TDCI :?:
Postby Transit like me@daa » Mon Sep 01, 2014 3:56 pm
No sure mate 2.0 diesel 85 260
Transit like me@daa
Postby Altransit » Mon Sep 01, 2014 6:20 pm
That will be a TDDi.
It's unlikely that you have 4 dodgy injectors all at once, so it wouldn't cut out for that reason, but could be fuel related if you haven't changed the filter :idea:
Postby Transit like me@daa » Mon Sep 01, 2014 8:16 pm
Cheers I drove home from work tonight
Van drove as normal
Parked up reved it to 3000 rpm cuts out after a few seconds with coil
Light on
Transit like me@daa
Postby ake » Tue Sep 02, 2014 6:31 am
Is it a good quality fuel filter? Or ebay cheap rubbish?
Postby Transit like me@daa » Tue Sep 02, 2014 7:10 am
Hi mate it was from euro parts
A dont think it was a cheap 1 £16 it cost
I've not fitted that yet tho
Transit like me@daa
Postby jay » Tue Sep 02, 2014 5:18 pm
fit the new filter but dont forget to fill it with fresh clean diesel before fitting otherwise engine will stop and they are hard to bleed
jay
Postby Transit like me@daa » Wed Sep 03, 2014 9:55 pm
Hi had a mate connect his diagnostic machine
Getting code p1665 and p0216
Does this mean diesel pumps knackered
Thank to all for there help
Transit like me@daa
Postby Transit like me@daa » Wed Sep 03, 2014 11:50 pm
My freind thinks it
Might be new Diesel
Pump
Required but when he first plugged diagnostic machine in it
Showed cam shaft sensor
Fault the disappeared and showed other faults and codes I mentioned earlier
But I drove home from
Work with no
Problems once this all happened
So does that mean pump would be ok
Was gonna buy camshaft sensor and try fit
My self
Could any one help
Transit like me@daa
Postby Altransit » Thu Sep 04, 2014 12:44 am
TDDi doesn't have a camshaft sensor :?
Users browsing this forum: jay@sandford
