chasper wrote:Its on a Chausson Flash 02 motorhome it has 3 batteries , 1 base vehicle and 2 leisure batteries. There is also a 130W solar panel. I suppose you are probably right about the battery which is under the drivers seat, it must be the original. Thanks.
chasper wrote:I have two Numax 86A batteries in the battery compartment under the bed.
chasper wrote:No it originally had a 100A battery, but i have fitted a 130w solar panel so i wanted more battery capacity. It works well.
chasper wrote:Just an update, I have changed the vehicle battery, but the problem still remains! ie, after a journey about 5 minutes after stopping the engine there is a crackley grinding sort of sound from the speedo area, the information panel lights up for a couple of seconds and the 4 clocks move anti clockwise for a couple of seconds, then it stops and about 2 seconds later it goes through then same cycle the tripometer resets to zero as well. After about 20 minutes it stops doing it and everything is normal.
chasper wrote:Its a 2007 2.2 model. I suppose its a trip to a Ford garage then.
chasper wrote:Would it be a big job to try some other clocks? I'm in North Devon by the way.
