loot34 wrote:Did the tongue test on the circuit and there's power throughout but can't feel any on the main chip
No idea if the trigger is live negative or can bus/signal need to put a meter on the output from the van and see what it shows.
My alarm is working but after locking it there was a backup sounder fault, maybe i should just connect the sounder to it? I know 100% that the live and negative are correct at the siren but signal doesn't react to + or -. May even have damaged it by doing that but it's dead at the moment anyway.
Science eh
paul2012 wrote: Tongue test... those chips are not edible
limitedblack wrote:You say you have just under 12v from the BCM, 1.6v from battery backup, no voltage at main ic on sensor pcb, correct?
Going back to one of your previous complex conversions, have you connected the earth
bigjohnthomas wrote:It would be much easier to just get one of those alarms that connect across your battery and say "get back you b*stard or I will break you legs"
30 quid
