Vibration at idle
Vibration at idle
Postby Davee75 » Tue Oct 21, 2014 6:51 pm
So been driving this for a good few days now, really like it but i am trying to find an annoying buzz/vibe which only happens at idle, once over 1000rpm it disappears....
Thought it was something trapped in the gap by the clocks, i found a few coins down there but it didn't help the issue. Then i thought it was in the gap between the windscreen and dash, only found a pen there so again no help..
On opening the bonnet i noticed the airbox moving a fair bit (if i press on it it stops) so i tightened up the fixing bolts a bit as there was a bit of play there but still no good though this isn't moving about as much!
I have since found that it seems like its somewhere in/behind the lining to the left of the clutch pedal as by pressing on this area it stops :?
Any similar experiences or idea's
Davee75
Re: Vibration at idle
Postby ake » Tue Oct 21, 2014 8:53 pm
What van? What age?
Heater pipes vibrating on bulkhead is common on Mk 7
Postby Davee75 » Tue Oct 21, 2014 9:28 pm
Sorry ake, its an 07 110 260 2.2tdci.
Cheers for the reply, i will take a look tomorrow :)
Davee75
Postby ake » Wed Oct 22, 2014 10:58 am
Definately look at pipes on bulkhead then..
Postby Davee75 » Wed Oct 22, 2014 7:18 pm
Thanks ake, i had a quick look today then realised i didn't know what i was looking for :oops:
Where about's can i find them please? Do i need to get under it or take apart the dashboard?
Yes i am pretty useless! :D
Davee75
Postby ake » Wed Oct 22, 2014 7:46 pm
Open bonnet, look behind engine where heater pipes go through bulkhead
Postby Davee75 » Fri Oct 24, 2014 3:14 pm
WOW too easy!!! Wedged a bit of sponge in there..... No more VIBES :lol: has been driving me bonkers!!!
Cheers ake BIG THANKS 8)
Davee75
Postby ake » Fri Oct 24, 2014 7:12 pm
No problem, thanks for reporting back ;)
