by flyingclutchman » Fri Oct 24, 2014 8:09 pm
If you've got a concentric fitted (inside the bellhousing) which I think your model has, that's likely to be the cause. They can suck air in without leaking fluid out (good trick eh?) This is a common problem on vauxhall vivaros as well. (All the concentrics are made by the same company) Unfortunately it's a major job as you have to take the box out. Of course while you're changing the cylinder you want to change the clutch, then you also want to change the dmf and suddenly you have a massive bill. You might want to try changing the master cylinder first, as it's a quicker cheaper job, but your description is very typical of a faulty concentric
