karl mcghee wrote:correction they may be the same base but its the combustion bowls in the piston are different anything over 110 tdci have diffrent pistons
pugbug wrote:karl mcghee wrote:correction they may be the same base but its the combustion bowls in the piston are different anything over 110 tdci have diffrent pistons
Is that because spray angles of injectors are diferent on the higher powered ones
loot34 wrote:Pics or it didn't happen
martynx wrote:loot34 wrote:Pics or it didn't happen
Interesting
karl mcghee wrote:pugbug wrote:karl mcghee wrote:correction they may be the same base but its the combustion bowls in the piston are different anything over 110 tdci have diffrent pistons
correct they do use different sray patterns hence bigger bowls for bigger injectors
limitedblack wrote:I've read many posts regarding differences, and this is the very first one that has any facts. Other than hearsay no one knew the differences. I had read somewhere that the lower powered units didn't have the cooling oil spray on the piston underside, unlike the higher power. But again it's just hearsay.
