retro fit elec windows
Postby dodgy01 » Tue Oct 28, 2014 7:20 pm
i may of purchased a 2007 280
it does not have elec windows and i hate winders
so after a root around at work I've found a pair of elec regulators and switches BUT it there a way i can make these work without the van being wired for elec windows
can i power the motors directly from the switch or what else do i need to find
thanks
dodgy01
Re: retro fit elec windows
Postby loot » Tue Oct 28, 2014 10:33 pm
Mine were plug and play, you need the window looms too, check in the A pillar connectors where the door looms plug into the dash loom,if they have all but 1 wire in there then you should only need a relay/fuse.
I swapped my doors as they were crap and i fitted lecky ones and fitted the fuse/relay and bobs your aunty :o
If you don't have the wires then it's 2 cables to link the dr/ps switches and fused live and chassis earth at both doors, do you have door cards with switch pods in?
Only problem is they are all black wires :-(
Also you may get the one touch relay as part of the drivers loom.
Ids map here
loot
Postby dodgy01 » Tue Oct 28, 2014 10:36 pm
i have the looms from the doors with the door cards and switches
ill have a look tomorrow
thanks
dodgy01
Postby stevo » Tue Oct 28, 2014 10:39 pm
The hardest part is gettin the wires through the rubber gaitor through to the door, bloody pain in the arse.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby dodgy01 » Tue Oct 28, 2014 10:40 pm
where do i need to fit a fuse/relay please
dodgy01
Postby stevo » Tue Oct 28, 2014 10:42 pm
There's a one touch control unit that sits in the drivers side door, that's the only relay. Fuse obviously sits in its own slot in the fuse board.
Formely ibanez2005
stevo
Postby stevo » Tue Oct 28, 2014 10:52 pm
Punto helped me massively, finding the bits I needed to do mine.
Even though I have a high spec loom I didnt (or couldn't find) the electric window loom.
I ran the wires in myself, pretty simple with the aid of a haynes manual. Didn't gave the connectors for the switches either so had to solder them direct which isn't ideal but it worked. Only problem I've had is the one motor looks to be on its way out.
Formely ibanez2005
stevo
Postby loot » Tue Oct 28, 2014 10:56 pm
ibanez2005 wrote:There's a one touch control unit that sits in the drivers side door, that's the only relay. Fuse obviously sits in its own slot in the fuse board.
That's right :-)
The one touch relay is only for the sticky down on the drivers door :-)
Fuse f56 30A in glove fusebox is the only thing needed, got a feeling it is a big pink one not a spade standard type.
Ids map here
loot
Postby stevo » Tue Oct 28, 2014 11:01 pm
Mine is a standard 30 amp fuse. Blew so many putting mine in lol
Formely ibanez2005
stevo
Postby loot » Tue Oct 28, 2014 11:06 pm
ibanez2005 wrote:Mine is a standard 30 amp fuse. Blew so many putting mine in lol
Mk6?
Ids map here
loot
Postby stevo » Tue Oct 28, 2014 11:08 pm
Yeah
Formely ibanez2005
stevo
Postby loot » Tue Oct 28, 2014 11:09 pm
May be the same may not but either way Is f56 :-)
Ids map here
loot
Postby stevo » Tue Oct 28, 2014 11:11 pm
Still a b*stard to fit if you don't have the loom lol
Formely ibanez2005
stevo
Postby Brains_transit » Tue Oct 28, 2014 11:20 pm
All mk6 have the full half loom with all the wires needed for EW. the EW loom plugs in at the speaker area loom plug
Brains_transit
Postby loot » Tue Oct 28, 2014 11:21 pm
Personally I'd probably get the electric door looms, that way you don't have to try and feed wires through the rubber, the rest is a bit fiddly behind the dash but quite easy.
Did the reverse camera wiring through the back doors trunking, bloody nightmare :lol:
Ids map here
loot
