Brains Mk6 transit wrote:All mk6 have the full half loom with all the wires needed for EW. the EW loom plugs in at the speaker area loom plug
Op has mk7
loot34 wrote:Brains Mk6 transit wrote:All mk6 have the full half loom with all the wires needed for EW. the EW loom plugs in at the speaker area loom plug
Op has mk7
loot34 wrote:The one touch relay is only for the sticky down on the drivers door
Fuse f56 30A in glove fusebox is the only thing needed, got a feeling it is a big pink one not a spade standard type.
motorman116 wrote:loot34 wrote:The one touch relay is only for the sticky down on the drivers door
You forgot about the relay that goes into the fuse box for the electric windows, I think that its R19 if I remember rightly ????
loot34 wrote:I ignored that as it is listed as r19 ignition relay kl-2 which i thought would have to be present anyway but i didn't give it much more thought, maybe ignition is kl 15 r21? So r19 may be needed although i only recall fitting 1 item, a fuse or a relay take your pick
So f56 and r19 if not there
loot34 wrote:Van can you get a tourneo rear view mirror that goes on the rain sensor T2myd?
t2myd wrote:I've got about 20 doors with electric windows if anyone needs any
dodgy01 wrote:t2myd wrote:I've got about 20 doors with electric windows if anyone needs any
i need the wiring and the box of tricks with the switch from a drivers door if you have 1 please
