Hi all,
Problem with my transit, have never looked at engine before so got a Haynes manual, was told by a friend that it could be something to do with rocker arms coming loose, so i followed Haynes manual and striped engine to rockers, to find two bolt snapped and the carrier where they bolt in has snapped chunks off, also the timing chain tensioner had broke and chain had a few links missing which i found in the sump (after removal), so ordered 2nd hand head and chain with gasket and seal etc,,, as waiting for delivery i though id strip to gasket and replace as never been before, (117000 on clock), with cylinder head off? due to what happened for it to all go wrong, would there be anything wrong with the vales? if so how would i go about checking them? or replacing them?
Many thanks
