Should tickover around the 850 (+/- 50 rpm) mark i'd think.....
Something you've done has made a difference,so now i'd be tempted to try and re-learn the values in PCM.
Ideally you would reset these with diag tool,but same can be done by pulling the memory feed fuse for engine management.
(Should be a 3A fuse,looks to be fuse no.40 in Aux fusebox,underbonnet i assume)
When you have half an hr 'spare'....
Pull fuse for say 5 mins,or failing that disconnect battery,
Then refit / re-connect.
Start it up from flat cold and let it idle untouched for 2 mins,
Then hold revs at 2000 rpm for 2 mins,
Then go on at least a 5 miles roadtest with varying speeds and loads,hitting full throttle at least once.
This should set a base map for running parameters,it will then start to learn every 'drive cycle'
This is classed as from cold to above 70 degrees coolant temp (just above white on temp guage).
See if it improves the running
rikki19 wrote:Glad you managed to remove it so easily , your arms must be 6" longer than mine ... lol , or maybe the location was modified from the earlier mk 6's . Apparently the manual starts off with " remove intake manifold " and removing the pipe that runs around the back from the exhaust . Did you get the part no. from the DPFE ?
Users browsing this forum: Google [Bot], Majestic-12 [Bot], md89
