How many Mk6 petrol/lpg are out there.
Re: How many Mk6 petrol/lpg are out there.
Postby moto » Wed Apr 05, 2017 1:36 pm
mealic wrote:Is yours by chance a moondust silver ex clear channel /ad-shel company owned? They used to service the shelters around London and had the plastic lining installed and 12v socket outlets in the back. Possibly a prefix of VK in the reg.
Lol! You know your stuff! Yes, Ex Clear Channel, VK prefix! - all the back had been removed. You can see it had some heavy duty something in there! No sockets, might have to have a poke around and see if the inverter is still there somewhere, could be handy! Well that saves on putting a split charger and battery in. :D
moto
Postby mealic » Wed Apr 05, 2017 8:28 pm
They were fitted with at least two 12v DIN accessory sockets. One around the SLD area and another on the rear pillar to the rear doors.This might help you find some cabling.Never seen one with an inverter fitted as standard though.
`04 2.3 petrol/LPG
mealic
Postby moto » Wed Apr 05, 2017 10:30 pm
Ah yes! we have them there! Will be useful on it's new recovery role!
Going through it at the moment, the Alternator is next on list, prop UJ/Diff bearing, Service and tyres. 2 private owners after leaving Clear Channel - neither went far, last owner had it four years and did 5,000 miles in four years. Oil is black as! lol, probably not been changed in four years. Other than that, drives really well! :)
moto
Postby moto » Sat Apr 08, 2017 8:39 am
Had a shock at the fuela station last night.....topping up obliviously, and some man points underneath - gas everywhere! Turned off pump, had a look and it all seems to be fine. Not sure if it was because the station was having a gas delivery, but either the pump didn't turn off and the pressure relief valve let off off or if there is a leak. It still says full on the gauge, so hoping it was pressure releif and a fault at the pump!
moto
Postby skenk » Sun Apr 09, 2017 3:47 pm
Once upon filling up I got a major leak from somewhere near the tanks at the back, sounds similar to what you describe - gas everywhere! It was a split hose, the tanks had to be dropped down to replace it. Simple job for the LPG mechanic once the bolts under the floor allowing the gas tanks to be dropped had been found.
Mk6 2003 2.3 LPG/Petrol SWB MR workhorse with tweaks
Mk5 1999, died of rot RIP 2009
skenk
Postby moto » Mon Apr 10, 2017 8:11 pm
I had held gas and has been running fine - went to refill and leak as soon as connected, so my thoughts of a pressure valve venting were hopeful - looks like you're right skenk, a split hose, I'll have a poke about later! Typical! gotta do two days of long runs and no gas! lol!
By the fact it didn't blow the lot out straight away must be a filler hose gone.
moto
Postby Holtwood » Wed Apr 26, 2017 1:36 am
Moto did you get this fixed? My 350 will not fill up, it vents as soon as the fill host is pressurised. Not sure if its the mulivalve or hose. Looks like gas is coming from tank area under van.
Holtwood
Postby moto » Wed Apr 26, 2017 1:19 pm
Having been going through the list, and about to drop the LPG tanks to replace the hoses,(nobody wants to do it!) noticed a pinhole also present in skin of rear tank, with what looks to be silver thermal jacket beneath. Looks like tanks need replacing as well! Looking online for some tanks now. Did see some twin range rover ones that look intentical.
moto
Postby moto » Wed May 03, 2017 1:00 pm
Holtwood wrote:Moto did you get this fixed? My 350 will not fill up, it vents as soon as the fill host is pressurised. Not sure if its the mulivalve or hose. Looks like gas is coming from tank area under van.
Sorry, I missed your comment there. Seems to have a weak point on the rubber hoses and looks like venting. No too difficult to do by the looks of it, and pipes are reletively cheap if you have them made at a local hydraulic hose company. You may need to lift your floor and there will be 6 bolts that hold the tank in. You will need a second paid of eyes/hands underneath to drop onto a pallet or jack affair and ensure no further pipe damage is done.
Not actually completed yet as went away, and day before I left started overheating - turned out to be the stat. I think i am paying the price for a van doing so little mileage in the last 4 years of its' life!
moto
Postby Sixstring » Wed Jul 26, 2017 10:09 am
T350 LWB 2002....about 24 on petrol, 21 on LPG, but you DO notice a horsepower decrease on LPG.
Sixstring
Postby mad dog 03 2.3 lpg » Sun Aug 13, 2017 3:45 pm
Postby moschops » Fri May 15, 2015 7:09 am
Forum name ................. Model..................... LPG working Y/N
1/ mealic ...................swb low roof 04..................Yes 111,000 factory fit
2/ Madmart132.............Jumbo 03 lpg.....................Yes ( But not Factory fit !!) 250,000 miles now 25 mpg Pet 17-22.5 mpg gas
3/ User774................. Swb low roof 54..................Yes 200,000 miles, london traffic so no idea of mpg. Lpg used in traffic, petrol used at speed.
4/rogerw....................Swb low roof 03 ..................None
5/ Rowdey-.................MWB/MR. 2003................... 205,000. Factory LPG with extra 90l tank.
6/ rikki19...................MWB mid roof 2001 ..............2.3 petrol 270klms....no lpg
7/ Chimplad28.............Mwb high roof, 51.................Yes,119000, Aftermarket 2.3 Petrol, Roughly 20mpg on gas
8/ Andycaravan............LWB High roof 2002...............Yes ( with rpobs ) 195k factory 18 - 20 mpg fitted extra 145 ltr tank get 750+ miles per fill
9/ injected.................MWB pick up 02....................yes, was Vialle now BRC
10/ injected................MWB pick up 02................... Yes, was Vialle, now BRC
11/ injected................MWB pick up 05....................yes, factory LPG
12/ zobby...................MWB high Roof 03.................55,500 miles, factory LPG NOT-WORKING, Petrol Perfect!!
13/ Captain Hook..........SWB Lowroof 2004.................Factory LPG
14/ Captain Hook..........SWB Lowroof 2005.................Factory LPG (Project!)
15/ Weeds...................SWB low roof 01...................No LPG 250K/Kms
16/ VGM.....................SWB Low Roof 53..................2.3 LPG, 145k LPG Not Working Fine On Petrol :?
17/ moschops...............LWB Semi-Hi roof................Petrol ok, LPG only works when engine v.hot
18/Kevin mwb Hi roof BRC after market works well about 22 mpg on gas.S
19/mad dog 03 2.3 lpg....SWB Low Roof 03 UK..............2.3 LPG 216k LPG SEEMS TO BE TEMPERMENTAL OR GAUGES STICKIN AGAIN WELDED UP FOR MOT PRETTY SOLID N FLIES LIKE A ROCKET 6 SEATS :D :lol: :lol: :lol: :twisted: :twisted:
mad dog 03 2.3 lpg
Postby Oldfossil1 » Mon Aug 21, 2017 11:11 pm
I collect mine tomorrow (Tuesday).
What's the lpg like for filling up?
Oldfossil1
Postby mealic » Fri Aug 25, 2017 7:15 am
I think most factory fit Necam Koltec systems have the 55l tanks.. If I were you i`d put maybe 10l in to make sure the system works ok.
`04 2.3 petrol/LPG
mealic
Postby Oldfossil1 » Fri Aug 25, 2017 5:02 pm
mealic wrote:I think most factory fit Necam Koltec systems have the 55l tanks.. If I were you i`d put maybe 10l in to make sure the system works ok.
Thanks. :wink:
Oldfossil1
Postby thanuttiscotsman » Tue Sep 19, 2017 6:20 pm
One sold in Edinburgh last week with lpg still running.
Rossco
1996 transit swb 80 2.5di
1989 bx 16 valve gti nos and all the rest!
thanuttiscotsman
