How many Mk6 petrol/lpg are out there.
Re: How many Mk6 petrol/lpg are out there.
Postby TheGardener » Tue Sep 19, 2017 10:31 pm
My 2004 (53 plate) Moondust Silver Transit is currently on the bay if anyone is interested, the gas system works and has been for about 18mths. I wonder if it is an ex clear channel as it has the 2 sockets in the rear, one by the sld and one on the rear pillar by the back door.
2004 FORD TRANSIT 2.3 PETROL LPG SPARES OR REPAIRS
£ 425.00 - did not sell
Ended Fri Oct 6th  3:04am BST
Seller: vgm2015
All the best
Darren
1974 Triumph 1500TC
1968 Triumph Vitesse (Undergoing Resto)
Based Nr Colchester, Essex
TheGardener
Postby TheGardener » Mon Sep 25, 2017 8:08 pm
I've just put an new rpm filter on the bay if anybody needs one, £89 quid now on there with delivery, I've put on the bay for £50 ono with free post
FORD TRANSIT 2.3 LPG RPM FILTER NEW
£ 50.00 - SOLD (fixed price)
Ended Sat Oct 7th  2:26pm BST
Seller: vgm2015
Cheers
Darren
1974 Triumph 1500TC
TheGardener
Postby Ian williams » Sat Jan 27, 2018 10:04 pm
I have a 2007 transit 2.2 lpg on a mazda engine are they any good on gas.what lpg system is on it
Ian
Sent from my SM-G900F using Tapatalk
Ian williams
Postby madmart132 » Tue Jan 30, 2018 1:59 am
Hi Ian most of us on here have MK6 vans not really to sure on MK7 , ford did not make a factory lpg version of the mk7 so look under the bonnet for a small black box ( the lpg ecu ) with wires leading to the gas injectors, it should have the name of the software manufacturer written on it .
madmart132
Postby Oldfossil1 » Tue Jan 30, 2018 2:26 am
Have owned my van for 5 months now.
Had a surprise a recently when spotting a similar T300 this particular van was only running single fuel and not both.
Oldfossil1
Postby gasman » Sun Feb 25, 2018 10:00 pm
Forum name ................. Model..................... LPG working Y/N
1/ mealic ...................swb low roof 04..................Yes 111,000 factory fit
2/ Madmart132.............Jumbo 03 lpg.....................Yes ( But not Factory fit !!) 250,000 miles now 25 mpg Pet 17-22.5 mpg gas
3/ User774................. Swb low roof 54..................Yes 200,000 miles, london traffic so no idea of mpg. Lpg used in traffic, petrol used at speed.
4/rogerw....................Swb low roof 03 ..................None
5/ Rowdey-.................MWB/MR. 2003................... 205,000. Factory LPG with extra 90l tank.
6/ rikki19...................MWB mid roof 2001 ..............2.3 petrol 270klms....no lpg
7/ Chimplad28.............Mwb high roof, 51.................Yes,119000, Aftermarket 2.3 Petrol, Roughly 20mpg on gas
8/ Andycaravan............LWB High roof 2002...............Yes ( with rpobs ) 195k factory 18 - 20 mpg fitted extra 145 ltr tank get 750+ miles per fill
9/ injected.................MWB pick up 02....................yes, was Vialle now BRC
10/ injected................MWB pick up 02................... Yes, was Vialle, now BRC
11/ injected................MWB pick up 05....................yes, factory LPG
12/ zobby...................MWB high Roof 03.................55,500 miles, factory LPG NOT-WORKING, Petrol Perfect!!
13/ Captain Hook..........SWB Lowroof 2004.................Factory LPG
14/ Captain Hook..........SWB Lowroof 2005.................Factory LPG (Project!)
15/ Weeds...................SWB low roof 01...................No LPG 250K/Kms
16/ VGM.....................SWB Low Roof 53..................2.3 LPG, 145k LPG Not Working Fine On Petrol :?
17/ moschops...............LWB Semi-Hi roof................Petrol ok, LPG only works when engine v.hot
18/Kevin mwb Hi roof BRC after market works well about 22 mpg on gas.S
19/mad dog 03 2.3 lpg....SWB Low Roof 03 UK..............2.3 LPG 216k LPG SEEMS TO BE TEMPERMENTAL OR GAUGES STICKIN AGAIN WELDED UP FOR MOT PRETTY SOLID N FLIES LIKE A ROCKET 6 SEATS :D :lol: :lol: :lol: :twisted: :twisted:
20/Gasman.................SWB Low Roof 2004.................2.3 ,Factory LPG,99k,lpg works
gasman
Postby Oldfossil1 » Sun Feb 25, 2018 10:07 pm
Ahem.
Old Fossil T300 LPG working Y White swb medium roof 52 120000 2.3 factory fit
Oldfossil1
Postby flashbaztard » Tue Mar 13, 2018 10:23 pm
2003 swb running gas 165k
Sometimes seems to misfire,
(I had a convoy with factory fitted lpg and there was a hidden switch so you could turn gas off do transits have these?)
flashbaztard
Postby moto » Sun Apr 08, 2018 7:15 pm
If it is factory there should be a switch on the dash with a bottle on it. That will be the LPG one. If your misfire is slight, have a look at the coil packs, and see if the connector port on the coil pack is damaged from heavy handling - they appear quite fragile. I used resin to reinforce the connection so it is a little more bulletproof. Check that before getting the wallet out!
Whilst here - anyone have the OBD wiring diagram? Not for the ports, but for where it goes from there (the bus live on main loometc) - this one seems to have been fiddled with! lol!
moto
Postby CROSSFIREROB » Wed Apr 25, 2018 10:08 pm
Today I bought a new RPM filter i didn't need one ,but I heard they were to stop making them , I didn't believe the guy so I had a ring around and couldn't get one , so I would recommend getting a spare while you still can ,seeing as they have a habit of failing .Just saying :D
Rockin and a rollin all day long !
CROSSFIREROB
Postby madmart132 » Fri Apr 27, 2018 11:17 pm
Hi Bob I am just going to replace the complete front end system on my van,i can then do the diagnostics myself as nobody seems able to work on the factory systems .
By the way now you have replaced the cat how fast is your van?
madmart132
Postby simon01775 » Wed May 02, 2018 10:46 pm
21/simon01775.............SWB Low Roof 2002................2.3 LPG 135k and LPG works but having issues with cooling fan not kicking in!!
simon01775
Postby trans-it-mad » Wed May 23, 2018 11:12 pm
22/ trans-it-mad...........LWB High Roof 2002.................YES factory, 87K it like to switch back to petrol, so I need to stop and restart
trans-it-mad
Postby johnniieee » Sat Jun 09, 2018 1:51 pm
Form name Model Mk6 LPG working
johnniieee swb low roof 06 Yes[/quote]
johnniieee
Postby johnniieee » Sat Jun 09, 2018 8:41 pm
johnniieee wrote:Form name Model Mk6 factory fitted LPG LPG working
[/quote]
johnniieee
Users browsing this forum: Bing [Bot], cornishpasty, E8RGD
