Hi All.
Ive just replaced my MK7 gearbox, clutch & DMF, selector cables along with crank sensor, the problem is its not wanting to start on its own!, theres not much fuel getting to the injectors, if i spray easystart down the tube by the MAS, it kicks into life and drives really well!, but when i turn it off NO START!!!
Any ideas???? thanks John
Ive looked on here and someone mentioned the Inertia switch?....
Ive just read the codes on the van and is coming up with U0140 - Unable to communicate with module - any suggestions??
