Problems Starting After Gearbox Change
Postby johnpettet » Sat Nov 22, 2014 1:31 pm
Hi All.
Ive just replaced my MK7 gearbox, clutch & DMF, selector cables along with crank sensor, the problem is its not wanting to start on its own!, theres not much fuel getting to the injectors, if i spray easystart down the tube by the MAS, it kicks into life and drives really well!, but when i turn it off NO START!!! :-(
Any ideas???? thanks John :?
Ive looked on here and someone mentioned the Inertia switch?....
Ive just read the codes on the van and is coming up with U0140 - Unable to communicate with module - any suggestions??
johnpettet
Re: Problems Starting After Gearbox Change
Postby Punto443 » Sat Nov 22, 2014 2:01 pm
It won't be the inerta switch if it runs after starting with easystart, of its even got an I.S.
Does it turn over fast or struggle? Also is there any Engine management lights on the dash?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby johnpettet » Sat Nov 22, 2014 2:09 pm
Punto443 wrote:It won't be the inerta switch if it runs after starting with easystart, of its even got an I.S.
It turns over fine, the EML code read
U0140 - lOST COMMUNICATION WITH BODY CONTROL MODULE
P1103 - Mass Air Flow Sens
JP
johnpettet
Postby Marty.H » Sat Nov 22, 2014 2:59 pm
Have you managed to pull on the loom at all and dislodge a plug or damage a wire.
Marty.H
Postby johnpettet » Sat Nov 22, 2014 3:01 pm
dont know, going to stick it on the ramp and check that every connector is on, crank connectors..... bloody vans!
johnpettet
Postby Punto443 » Sat Nov 22, 2014 3:10 pm
Checking the wiring is a good start, aswell as checking all the fuses :D
Start with the basics
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby bambi mk 1 » Sat Nov 22, 2014 7:44 pm
Try you old crankshaft sensor.Had one that would start cold and run all day knock it off when hot and it would not start till it cooled a bit.Snapon reader would not show any fault code.
bambi mk 1
Users browsing this forum: Bing [Bot], Google [Bot], sfnett
