dodgy01 wrote:i have no problem getting a fused supply via the relay but I'm trying to establish what pins on the door connector that i sent the power to and what pins i use to run the interconnecting wires
thanks
See above
thanks
dodgy01 wrote:im assuming ill need to add pins to the plug so ill try to find a old plug from another dead van we may have at work
then it will just be a case of working out how they have numbered the pins and we will be away
thanks
andy pp wrote:when I did this all I did was fit the motors and door looms in and they worked
dodgy01 wrote:so am i right that i do need these extra cables then ?
thanks
