Idiots guide to IDS
Re: Idiots guide to IDS
Postby loot » Tue Feb 14, 2017 12:05 pm
You have xprog:-)
V86 web, v86 licence patch, xprog will get you ids up and running.
Optionally is v86.04(minor update) c81 (calibrations but it is in Airthies Sig, 3.5gb tho) not really needed as you'll get later updates over Wi-Fi 8)
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 12:10 pm
Thanks again, I am as far as the evaluation license saying it will expire in 3 days, do I just press continue?
2007 SWB 110PS GLX Mk7
rimotu66
Postby loot » Tue Feb 14, 2017 12:31 pm
V86 doesn't have an evaluation licence.
Install v86 don't run shut down, restart then run v86 licence as admin and in xp3 mode, shut down.
Restart, run xprog as admin and lower choice-hq clone.
Run ids.
Non ford
00000
Uk
That's it.
Plug obd into the van with ign to pos 2.
Ids would id the van and ask you if the vin is correct etc.
Go to toolbox/selftest/all other etc and scan for fault codes.
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 12:52 pm
I think I have cocked it up and my main laptop has just decided to lose wifi connection :evil:
I have downloaded
v86 web
xprog
ids patch86
ids 86 04 update
do I need to uninstall one of them.
Sorry about this guys. :oops:
rimotu66
Postby loot » Tue Feb 14, 2017 1:12 pm
Do what i wrote above from a clean install of windows, if you don't do the v86 and licence how i said it won't work unless you clean windows again :-(
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 1:27 pm
I thought I had don't it as you said Loot I did tick non ford, 0000 and uk but when I try to run ids I get the evaluation page, if I have to reinstall w7 it will be next week when I am back on shift as the it tech did it for me and I don't have a disc. :? Any one want to buy a vcm?
rimotu66
Postby loot » Tue Feb 14, 2017 1:41 pm
Try a restore point to before ids :-)
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 2:06 pm
loot wrote:Try a restore point to before ids :-)
Done, I think I may of messed up last night, should not have had a drink :oops:
Your drop down shows
xprog and 86.04
custom 2.2 155ps calibration
Ford IDS V86 (Web Installer).exe
Fordxprog.zip
IDS_patch_86.exe
IDS-86.04 update.zip
vcm2 reset.txt
Which do I choose, hope you don't mind taking baby steps with me, just do not want to screw it up again and I do not need any of the discs that came with VCM?
rimotu66
Postby loot » Tue Feb 14, 2017 3:14 pm
Ahhhh do what i said above m8 that is it. :-)
You are just like me lol
Do 1 step at a time that i said and if unsure ask. :wink:
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 3:26 pm
loot wrote:Install v86 don't run shut down, restart then run v86 licence as admin and in xp3 mode, shut down.
Run ids.
Non ford
00000
Uk
That's it.
Ok so I am going to download Ford IDS installer and x prog and nothing else then do as you said. Jeez I feel dumb :roll:
Its running install wizard now but only had the option of English (American) for language :?:
Got a page up now asking me to install movimento group ab, is that part of it?
rimotu66
Postby loot » Tue Feb 14, 2017 3:47 pm
Yes that's a dependant it'll get that itself just click OK :-)
Once v86 is installed restart the laptop but don't run ids then on the v86 licence extract it to desktop if needs be then right click on it and properties and compatibility, xpsp3, and run as administrator then go out and run it.
That'll be ids installed and patched, unless you've buggered the registry by the first failed attempt in which case I'd choose to reinstall w7.
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 3:51 pm
Where do I see the licence?
rimotu66
Postby loot » Tue Feb 14, 2017 3:57 pm
Ids_patch_exe :-)
Ids map here
loot
Postby rimotu66 » Tue Feb 14, 2017 4:03 pm
Ok I have set it to xpsp3 (even though I am on w7 yes?)
I have downloaded xprog but not installed it yet, do I need to do that? Wish I lived in North Wales but I bet your glad I don't :lol:
Hang on I didn't download ids patch exe?
rimotu66
Postby loot » Tue Feb 14, 2017 4:08 pm
I've had worse lol, ignore xprog until you've installed v86 and used the patch (licence) you can run ids and in blue top menu look for software etc (bottom left is 3 tabs just click on them until you see what you want).
Once you are happy you can then xprog but either or doesn't matter. The important thing is the steps you take to do v86 and patch OK :-)
Ids map here
loot
Users browsing this forum: Google [Bot], steviebee
