Ah yes that's the 1:-)
Look on bcm for connector c4, unplug it and then split the 2 inner connectors and on 1 of them you'll be able to find pin 6, that is the negative switch for the 2 relays, positive is ignition linked the 2 relays to fuse f40(you may not have f40 so add it to the fusebox)
You don't need to worry about the actual on off switch for the screen as long as you have the connector where the button is on the dash.
Please note that i did that how to before i got wiring diagrams and it worked but i haven't read it all through again and there may be small discrepancies
I should make a new 1 with updated pictures etc.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
