by APH » Wed Apr 22, 2015 12:39 am
Under the passenger fuse box somewhere in the bundles of looms is a grey connector with a shorting plug plugged into it, you either need to change the plug for the non tacho shorting plug, or reconfigure the existing one to make it a non tacho type. At the moment the the speedo signal from the vans own speed sensor is not going to the dash as it was getting it via the tacho unit and the tacho speed sensor.
03 2.4 TDDI 90 t350 LWB HR white panel vanX reg 2.4 TDDI 90 t350 MWB MR Yellow Panel van56 reg lwb high roof connect, 1.8 tdci 90 t 220(\__/)
(")_(")
this is bunny
