Hi all
I have a Mk 7- 210,00 miles & still flying. However- it has developed a locking problem, which I suspect may be a battery.
Both key fobs seemed not to hold their charge, inasmuch as within 2 days of not using the van, I can't unlock it without putting the key in the ignition & running the engine for 5 mins. It's always started fine. Then I noticed that I had to re-enter the radio code every 2 days as well!
Dealer wanted to sell me 2 keys, but it seems odd both woulld go at the same time. I believe I read somewhere here that similar symptoms could occur if one of the batteries was shot.
Is this true,and if so, which battery would it be- front or rear?
Thanks in advance for your help- I know someone on here will know the answer
Rick
