loot wrote:Have you checked the 2 fuses taped up to the steering column?
loot wrote:Not likely
Brains_transit wrote:Only the fob is programmed to the CL control box. Do the rear doors lock if you only use the key in the drivers door
sjs205 wrote:Brains_transit wrote:Only the fob is programmed to the CL control box. Do the rear doors lock if you only use the key in the drivers door
I'm not sure I've tried that, I'll check it tomorrow... Too late now since the alarm goes off whenever it is "locked" and I open the back door.
robbie.cee wrote:Be worth checking for a broken or cut wire(s ) look where rear doors open, where the wires pass from door to van
