GG707 wrote:Good Morning,
Thanks everybody for your opinions, I believe that the clutch for the single mass is enough cm larger in diameter than the one for the dual mass
which also seems to make it last longer... but since you already have try it have you noticed extra noise or extra vibrations?
Ive driven Andy's van and cant say I noticed any real difference between his and mine (which still has the dual mass fitted) and Karl has reported that his van runs and drives perfect since fitting the solid mass flywheel/clutch recently (he also changed the spigot bearing) At the risk of repeating myself...it is IMPORTANT that you change the spigot bearing when replacing the clutch/flywheel (even if you stick with the dual mass) as the bearing will have taken a lot of stick from the worn/out of balance dual mass flywheel
