Drivers door lock question
Postby marc20231 » Sat Jul 04, 2015 1:23 am
Is it possible to disable the drivers door lock so that it no longer works and if so dose the remote central locking still work thanks
marc20231
Re: Drivers door lock question
Postby magical » Sat Jul 04, 2015 1:49 am
Is it just the key barrel your wanting to disable or locking mechanism itself
magical
Postby marc20231 » Sat Jul 04, 2015 3:51 am
Just the lock I don't want the doors to be able to be opened by a key
marc20231
Postby Mr RVM » Sat Jul 04, 2015 5:51 am
marc20231 wrote:Just the lock I don't want the doors to be able to be opened by a key
Yes you can have it set up that way :wink:
Mr RVM
Postby magical » Sat Jul 04, 2015 12:38 pm
Yes just take door card off inside and take the lock arm off which will disable key barrel then will only work from key fob remote hope that helps
magical
Postby marc20231 » Sat Jul 04, 2015 5:36 pm
thats great thanks guys will have a look at that thank you
marc20231
Postby wildman » Tue Dec 08, 2015 7:59 pm
Did you manage to do this? If so what does the locking arm look like.
I want to do this. Had a look but not sure what to take off
wildman
Postby knobby1 » Tue Dec 08, 2015 9:47 pm
wildman wrote:Did you manage to do this? If so what does the locking arm look like.
If you do this and your fob fails after deadlocking the van...it's angle grinder or smashed window time. :wink:
Postby squirrel93 » Tue Dec 08, 2015 10:11 pm
squirrel93
