t2myd wrote:On some 07 plate vans you can pull front window out ,I've a tibbie pick but your Probaly miles away from burnley
pp5858 wrote:Actually just realized that doors are double locked. So probably trying to break in to front was waste of time bc. of that.
Pulling the window out sounds something to look that could be helpful. Also considered breaking some window but they all seem to be expensive and I don't know will mk6 windows fit.
Punto443 wrote:t2myd wrote:On some 07 plate vans you can pull front window out ,I've a tibbie pick but your Probaly miles away from burnley
Finland's just up the road tommy
Cal1990 wrote:String small window out mate it's easy I done it before when remote never worked
pp5858 wrote:Tnx a lot for really good help. I will also look option to cut new key from the worn out that has been on my list but now in distress it in first sight seem'd hard.
Pulling out that small windown without breaking sounds good. I tried to look how that is done but didn't understand the process yet. Having some pointers for that or bit more detailed explanation how to try it could be helpful.
