I recently bought a transit 04 t280 and it's been fine right up until I was out the drive way and then pulled up to answer my phone.
I went to select first gear once I'd finished my call and I got nothing. No drive or feeling like it was in gear at all. I thought it could be the cables for the selector on the ball joints popping off but checked both ends and they are fine. Almost look new.
I have depressed the clutch and It returns with force and no noises
I'm not 100% but it feels like if I put the gear lever into first position I can almost glide across all the gears where they should be without returning it to neutral.
I have no idea or experience with transits and as such I'm a bit out of ideas.
I've had a search and no topic seems to be similar so I apologise if I'm asking a repeated question.
As ever, if anyone could provide me with some help then I will be eternally grateful.
Adam.
