by samwhich » Tue Feb 23, 2016 8:16 am
Hi all, sorry have been offline for a while and not staying up to date with this site.
Mine has been having similar issues lately very randomly and intermittently. Usually when taking off first thing in the morning (but not every morning) and a couple of times randomly while the engine is warm after a good drive with no issues. Most of the time, it is fine so I ignore the issue however it doesn't sound good when it is happening. It goes something like this:
1. Start Van
2. Foot on brake and select "D". (Engine continues to idle fine)
3. As soon as you barely even touch the accelerator, the clutch engages before the revs have a chance to get up and the van stalls.
When this occurs, I actually have to rev the engine in neutral with foot on brake pedal and then press "D" button so there are sufficient revs to take off and then it works. After that, the van will drive fine.
A friend of mine (young guy - ex Ford Mechanic) took it for a drive and believes the clutch seems fine (not slipping at all), HPU seems fine as it changes gear 99.9% of the time without issues so it could be that the TCM module might need to be "relearned". As I did drive around with a damaged gearbox for a while before getting a new 2nd hand one installed, this may have upset the TCM module giving this solution some credibility. Have not tried yet though so cant say.
Low cost things to try:
1. Have Ford do a TCM "relearn" for you
2. Have your ASM transmission "bled" (which is something you should do at least once a year apparently as this removes air bubbles from the trans fluid resulting in better/smoother shifting of gears
Please let me know if you have found a solution as I have not tried the above two things yet.
Cheers guys
2005 VH Ford Transit 2.4 TDi
Durashit Transmission
