Airthies wrote:What model eberspacher do you have and what control unit?
Have you checked in-line fuel filter for eberspacher? If it doesn't get enough fuel it could cause it to idle rather than fully firing.
P's I'm guessing it's an air heater?
andreasd083 wrote:The fan is not blowing hard enough on setting 1. The speed of the fan is the same with the motor running or off.
It heats up well, but I have to use step 2.
Airthies wrote:Can you confirm either:
fan works as normal when diesel heater is NOT on?
With diesel heater ON, fan only runs at speed 1 regardless of switch position?
andreasd083 wrote:Airthies wrote:Can you confirm either:
Ignition on - Fan runs on 0, 1 is the same as 0, 2 and 3 blows harder. I think it might be a problem with speed 1 as this probably should be harder than 0.
When heater runs and ignition off, it runs on speed 0 no matter of switch position.
