traction control ligth
Postby deadzone » Fri Nov 06, 2015 11:45 pm
Ford Transit Duratorq-Turbo Diesel Common Rail Injection 2.2L 2006.5, Tourneo
traction control ligth I drvie around london and not dont see the ligth come on
but traction control ligth comes when i seem to be doing a constant speed about 25 mins at 50 Mph .
Bought an OBD scanner
F Diagnostic Super 2 Interface Scanner USB Injector programming OBD OBD2 for Ford
Heres the read out from the scann
==PCM DTC None===
Successfull DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===ABS DTC None===
Module: Anti-Lock Brake / Traction Control Module
===END ABS DTC None===
===BCMii DTC B1048:7B-80===
Code: B1048 - Brake fluid level switch
Additional Fault Symptom:
- Low Fluid Level
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Body Control Module
===END BCMii DTC B1048:7B-80===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
Code: B1048 - Brake fluid level switch. looks like the switch needs replaceing here fluid level is fine
so i am at a bit of a loss of what to do next
thx
deadzone
Re: traction control ligth
Postby loot » Sat Nov 07, 2015 8:59 am
Try doing the test with handbrake off.
Ids map here
loot
Postby Frag » Sat Nov 07, 2015 10:20 pm
Try code reading it while fault is present ie lamp is on,
Check all tyres fitted are the same size,profile.
Poss steering angle sensor needs calibrating.
Is steering wheel straight ahead when driving on a straight road ?
Frag
Ford Technician
Postby deadzone » Sun Nov 08, 2015 10:29 pm
hi guys thanks for the replays much appreciated
Typical Ford Alloy wheels on a Transit tyres are all 205/65R/16c
Try code reading it while fault is present ie lamp is on.
Did not have my laptop to hand but will give that agao
wheel straight ahead when driving on a straight road.
when i got the van i did notice that it was pulling a bit to the left and tryed to have the tracking done to find out the
the ball jont lock nuts seized in place.
Have now replace have now replace the track rods and ball joins both sides and have the tracking done by ATS Euromaster
but the problem was there before all the work i did
Did not think to try that ill give that ago too.
I dont know if this makes a difference but i did noticed drive shaft near side front sticks out a a few millimetrers more then the off side
so you cant put on the Ford Alloy Centre Cap on properly is it likely to affect the positioning of the speed sensor on the back of the world at all ??
forget to mention as well but when I turn the engine off the light seems to reset don't don't come back again till i am doing a constant speed again
deadzone
Postby v8dave » Sun Nov 08, 2015 10:42 pm
If one drive shaft appears longer then check the abs rings on the cv joints, if they have different numbers of teeth then someone has fitted a replacement shaft that is wrong.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby deadzone » Tue Dec 01, 2015 11:26 am
hi all
quick up date
Still geting the same readings dont seem to change
thx all
deadzone
Postby deadzone » Tue Dec 01, 2015 11:37 am
hi v8dave
what i dont get is that its fine if i am doing a lot of stop start driveing in london as you do.
But if i go from archway round about to thw M1 to the fist to the service station then the ligth comes on or a little
it only seems to come on when doing a constant speed
drive shaft appears longer by mabey a mm or so just enough to stop you puting on the center cap in the middle of the alloy wheel
thx
deadzone
Postby loot » Tue Dec 01, 2015 11:39 am
Do the front wheel alignment and recalibrate the steering angle sensor.
Ids map here
loot
Postby Cookie Pjc » Mon Dec 21, 2015 11:40 pm
deadzone wrote:hi guys thanks for the replays much appreciated
I couldn't get the ford cap on the front near side of my alloys either.but the caps that came with the wheels fit on an off easy,could this cause problems?
Cookie Pjc
Postby deadzone » Mon Feb 22, 2016 7:39 pm
hi guys sorry for the long replay not had a chance too look at my van till now
have now rember to try reading the fault when it happens or when light comes on
here the read out
===ABS DTC C1B00:08-2B===
Code: C1B00 - Steering angle sensor
- Bus Signal/Message Failures
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Diagnostic Trouble Code details
The ESP lamp will be illuminated. There are other DTCs for the ABS module.
Possible causes are:
The SAS signal is implausible.
Steering Angle Sensor Not Calibrated
For Fault Code Type 54, the SASM is not calibrated. Calibrate the SASM.
Steering Angle Sensor Circuit Failure
The vehicle may have been involved in an accident.
Perform these checks
DO NOT replace the ABS module based on this DTC alone.
Check the SAS mounting and electrical connections. Check that the SAS is not loose or free to rotate.
Park the vehicle on level ground.
Check the steering and suspension geometry.
Replace the SAS.
Calibrate the new SAS after replacement.
After clearing the DTC, this DTC is not set again until after 30 seconds of ignition ON (Position II).
After the vehicle has been repaired, clear the DTC. Check to make sure it does not occur again after the ignition has been on (position II) for over 30 seconds.
Freeze Frame :
-GLOBTIM: -2247805 sec - Global real time
===END ABS DTC C1B00:08-2B===
- Low Fluid Level
Status:
===BCMii DTC B104F:17-48===
Code: B104F - Left Glass Break Detect
- Circuit Voltage Above Threshold
Status:
- Previously Set DTC - Not Present at Time of Request
- Test not complete
===END BCMii DTC B104F:17-48===
===RCM DTC None===
Successful DTC reading, no error codes found
deadzone
Postby deadzone » Mon Mar 27, 2017 2:47 pm
Traction control ligth
Thanks for the help guys sorry from the late replay I did get it sorted had to get the module reset I tried FORScan v2 Diagnostic Scanner for Fords
witch went in the modules and read it but did not seem to reset it .
we used a hand reader call AUTEL EU908 MOT Pro Dealer OBDII EOBD CAN Diagnostic Scanner Car Fault Scan Tool
deadzone
