by flashinapan » Wed May 11, 2016 1:54 pm
The saga continues ive had an secondhand axle put on after getting the recall done changed the bearing in the propshaft and still the noise and vibrating.
So this started when I bought the van and I took it to get the recall done at fords when getting it back the noise was still present so when I took it for mot the guy says there was some play from the prop shaft bearing, not a failure but mentioned it because of noise so I had it done. got it back and still bloody noise.so we had it in the air and wheels off ground revved it and nothing but did notice there was play in the wheels moving side to side. And so decided a second hand axle would solve the problem and it did solve the wheel issue but still that bloody noise and vibration now were back on the prop shaft again he says it might need balancing ? but cost just as much to get second hand prop shaft. so my question arises again what if its not the shaft ? what else could it be any input answers plz this bloody noise not to mention the money ! thx as always Colin
