Hi All,
I have a MK7 Transit 110 280. She has been a dream the last 4 months until one day I couldn't start her. I thought it was the battery so bought a new heavy duty one which solved the problem, until the other day. I have changed the crankshaft angle sensor (what a
that was to get to), Battery and a new starter motor. Unfortunately it seems to have done absolutely nothing. If anything, after the starter, its worse! I have cleaned all the terminals to the starter and the old starter was pretty clean when it came out, as was the crank angle sensor so it appears the dual mass I would assume is ok.
Things that spring to mind are relays and starter solenoids if such things are fitted on these vans. I have attached a video to show the problem, the van is in daily use as my work vehicle so I'm getting extremely desperate. Once started, it drives really well which is even more frustrating.
It's an Ex EDF van, 122k on the clock if that makes any difference.
Any help would be appreciated beyond belief.
Kind Regards,
Joe
Video -
http://sendvid.com/9eqh05fg
