If the rear doors make a noise then they are getting power but aren't unlocking
probably the door mechanism is bent or faulty inside, try leaning on the door and unlocking it, if you can only do it with the key then get someone to help, good luck
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
07 350 170ps
Ids v86 licence + v86.04 update + xprog
hereIds map
here
