Transit won't open
Transit won't open
Postby S26coolin » Wed Nov 25, 2015 11:10 am
Front doors unlock but rear button won't work. Wen I double click open it try's to open then locks all the doors. No drivers door lock just key
S26coolin
Re: Transit won't open
Postby v8dave » Wed Nov 25, 2015 1:40 pm
What mark ? 6 or 7
Have you checked all the fuses ?
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby S26coolin » Wed Nov 25, 2015 2:07 pm
Mk6 with mk7 doors but side door handle is snapped so access only through rear doors. If I cut wire loom will that release door ?
S26coolin
Postby v8dave » Wed Nov 25, 2015 2:18 pm
No.
You need power to the lock to unlock it. I don't have the wiring info to hand at the moment.
Should have fixed the side door lock so you can access the interior controls of the rear doors.....
v8dave
Postby S26coolin » Wed Nov 25, 2015 2:24 pm
What's my option now then apart from bending top of door down? How about smash rhs rear light out to get to wire loom
S26coolin
Postby loot » Wed Nov 25, 2015 2:29 pm
So when you unlock can you hear the back doors make a sound? Or are they dead?
Ids map here
loot
Postby Brains_transit » Wed Nov 25, 2015 3:41 pm
On a mk6 there's a wire to earth at the CL control box and it unlocks the rear doors
Earth this wire
Brains_transit
Postby S26coolin » Wed Nov 25, 2015 7:17 pm
Yes rear doors make a noise but don't unlock. We're will I find that plug?
S26coolin
Postby loot » Wed Nov 25, 2015 7:50 pm
If the rear doors make a noise then they are getting power but aren't unlocking :-( probably the door mechanism is bent or faulty inside, try leaning on the door and unlocking it, if you can only do it with the key then get someone to help, good luck :-)
Ids map here
loot
Postby S26coolin » Wed Nov 25, 2015 8:04 pm
Nope I think it's guna require damage
S26coolin
Postby loot » Wed Nov 25, 2015 9:35 pm
Oh dear :-( you'll have to find out what is cheapest to replace.
Ids map here
loot
Postby S26coolin » Thu Nov 26, 2015 8:30 am
Managed to take headrest out get a mate both lay against dash and kick the ply lined bulkhead off then climb through. After I'd opened the rear door they seem to now open and lock again all fine. Strange these transit vans haha. Cheers for the tips tho guys
S26coolin
Postby Herts » Thu Nov 26, 2015 8:36 am
Fix your side door before you do anything else!
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
