rogerw wrote:soprano1982 wrote:Air con is the one thing that I miss in my van - I'd love to retro fit in to the mk7
Aircon is essential
Haha I know it is , I'm hoping Paul's gonna tell me it's easy haha and offer up his services
Aircon is essential
bikenut wrote:Thanks for the replies lads.
Guy if you look at the pics Paul kindly posted is the layout of the pipes etc the same on a RWD and is the plug from main harness alongside the o/s headlight as the pump will be mounted on other side of the engine. Thanks
Guy88 wrote:bikenut wrote:Thanks for the replies lads.
No, on the RWD there is a plug under the fuse box for the Air con jumper to plug into,
The pipes run along the bottom of the engine and to the compressor, other plugs are the same
bikenut wrote:My van does indeed have ABS and traction, Also when I fitted mk7 doors the electric window wiring was all present. Do you think this indicates high spec dash wiring. One confusing thing the guy I bought parts from said the van had no electric fans fitted.
soprano1982 wrote:rogerw wrote:soprano1982 wrote:Air con is the one thing that I miss in my van - I'd love to retro fit in to the mk7
Aircon is essential
Guy88 wrote:
theres loads of room, fan fits on rear of coolant radiator
Also as yours is RWD you will also have to fit the correct coolant radiator (wider on RWD with AC)
soprano1982 wrote:by any chance do you have a parts list Paul I'll get hunting
I know next to nowt about ac - so assuming the parts I need would be -compressor ,various pipes, receiver dryer , rad pack , cab rad/matrix , control panel switch , pressure switch , looms ? My van was a lx from the factory so not sure if it would have a loom - although it had the right spec bcm for adding cruise
bikenut wrote:DO either of you know how many pieces there are to the ducts. I have one piece that's sort of a splitter from two into one, I presume this is the centre piece. are the sides in one piece each so I am looking for four long ducts or are some of these in pieces ? I am dreading if I have to go to my local dealers because without a reg number they don't want to know as it may involve work. Is there anywhere online to obtain part numbers ? Thanks Mick.
