loot wrote:Yes it sounds like the fuel is getting cut off, deffo spinning dry at the end I think.
Will it do this then randomly start up later no problem? That typically it's similar to being flooded tho, won't start straight away so leaving it let's it dry up, but I've only known that on petrols
Did you say the solenoid is leaking or anything? Or was that just a guess based on the knocking?
It always starts after trying for a while. Today I used the primer pump in fuel filter and after a couple more attempts it started ( not sure if that was just coincidence) though very knocky and very rough, erratic idle. 60 secs of raised revs and it clears as always.
It is starting to have knocking sound all the time driving though even miles after its cleared.
