Jim Archer wrote:Did the 'fully reconditioned' pump have a new diaphram and seal?
Jim
Yes new diaphragm, seals and Ecu which includes solenoid and sensor.
Jim
Jason_app wrote:Jim Archer wrote:Did the 'fully reconditioned' pump have a new diaphram and seal?
Jim
andz327 wrote:Sounds like oil starvation has killed your engine from the bottom up mate, best to replace your engine rather than a rebuild
loot wrote:Jason, after a bit of messing does it run normally?
karl wrote:Jason_app wrote:Jim Archer wrote:Did the 'fully reconditioned' pump have a new diaphram and seal?
Jim
you have a picture of your new pump
Jason_app wrote:andz327 wrote:Sounds like oil starvation has killed your engine from the bottom up mate, best to replace your engine rather than a rebuild
It's not likely to be oil starvation. Had new oil pump twice.
andz327 wrote:Could it be drawing a bit of air up at the fuel filter side, when left over night the fuel is running back and when you start up and leave it ticking over there's enough fuel in the pump to run at tick over long enough to suck the fuel back up without air getting to pump, but if you start it up and rev it up its sucking air and fuel up into the pump side and making it run rough
Jason_app wrote:Ford main dealer IDS picked up p0252, pump data mismatch code.
Ive been told that with a cps error there also that the fault is most likely in the loom or ecu.
