by loot » Thu Mar 24, 2016 8:50 am
Crank sensor aren't that expensive and plug n play.
Ids tells you if it is synching, i guess there will be a setting in snap on that can read the crank buy i don't know.
Check all fuses including the bcm fuses are good.
You're pcm and the 2012 pcm are different i think.
Check relays r4 r6 r8 are activating with key on.
Last resort are to get a pcm from the breakers and install it.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
