Starter motor sticking.
Postby jhsmaclean » Sun Jun 17, 2007 9:59 am
I have had three new starter motors on my Transit 350 LWB2001. They last about a month and then stick. Why is this happening and what is the solution.
jhsmaclean
Postby Guy88 » Sun Jun 17, 2007 10:07 am
dual mass flywheel breaking up and filling them with metal :(
2005 Ford F250 Super Duty
1974 MK1 V8 ex camper
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby motorwise » Sun Jun 17, 2007 11:52 am
what did the old starters look like? were they full of swarf?
http://www.motorwise.net
motorwise
Postby martynx » Tue Jun 19, 2007 9:29 pm
there was a note with a new starter that i bought that said you must remove the gearbox & clean out all dust & crap prior to fitting otherwise no warranty on the unit !!!!
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby motorwise » Tue Jun 19, 2007 10:07 pm
martynx wrote:there was a note with a new starter that i bought that said you must remove the gearbox & clean out all dust & crap prior to fitting otherwise no warranty on the unit !!!!
did it actually say "crap" on the note :lol: :wink:
motorwise
Postby transitgeoff » Tue Jun 19, 2007 10:37 pm
this is true thou and a problem, i sell new starters and this problem with carbon from the flywheel and the magnetic field of the starter attracting it is a problem because people come back and want money back or exchanges and its there fault well there flywheels, as soon as theres no more dm flywheels the better :D
transitgeoff
Postby jhsmaclean » Wed Jun 20, 2007 9:16 am
transitgeoff wrote:this is true thou and a problem, i sell new starters and this problem with carbon from the flywheel and the magnetic field of the starter attracting it is a problem because people come back and want money back or exchanges and its there fault well there flywheels, as soon as theres no more dm flywheels the better :D
Thanks the flywheel has been changed and that is not the problem, it may be heat as a grease like substance is dripping from the bottom of the starter motor.
jhsmaclean
