nedforceone wrote:Surely the tddi pumps are not as bad as they are in the devils engine (tdci) where you have to change pump injectors filter and flush the fuel system, then move to the country and become a spoon whittler. N
Diesel jones in Manchester do tddi re con pumps from £180 plus vat. N
karl wrote:nedforceone wrote:Surely the tddi pumps are not as bad as they are in the devils engine (tdci) where you have to change pump injectors filter and flush the fuel system, then move to the country and become a spoon whittler. N
dont think so more like £500 plus the vat
fedupwithford wrote:I have finally got a code reader for the van and I am getting the following faults with it:
P1563 Injection Pump Control Module Requesting Engine Stop
P1664 Injection Pump Control Module Malfunction
P0335 Crankshaft Position Sensor A Circuit
Does this mean I need a new pump and crankshaft position sensor? What is the best plan of action from here?
MK7 user wrote:fedupwithford wrote:I have finally got a code reader for the van and I am getting the following faults with it:
There must be 9 billion threads in the forum archives (I may have exaggerated) pointing to hard pump code failures P1664 & P1564.
You don't have P1564 logged & taking the cost of a replacement pump into account I'd be investigating the P0335 first
karl wrote:MK7 user wrote:
live data will be a good place to start checking the signal from the crank position sensor
I have my new crank sensor. What should the live data read?
The p0335 code has now been replaced by p0216 - Injection Timing Control Circuit Malfunction
do you think the crank sensor was bad to now throw up this code in its place? the other two codes remained the same.
MK7 user wrote:The idea was to prove the crank sensor was faulty WITHOUT spending money on a new one you may not need.
If you look in the "Technical How To" section, there is a thread by "APH" detailing how to test the pump wiring.
I don't dispute the high failure rates of tddi pumps....but I'd rather spend the 500 on spesh & lezzers than a pump I don't need.
