stephenferguson wrote:I have been modifying the headlight connections over from the mk6 loom to mk7 headlight, part of the front end conversion. There was two little faults, one being the headlight leveling didnt work and the second (not really being a fault just me being particular) being the indicators on the mk6's have a separate plug for the indicators.
To sort the headlight leveling, it was a simple case of moving one of the earths in the plug from pin 1 to 5. This gives the headlight leveling motor its earth to work.
To sort the indicators so that they work from the main plug, I cut the plug off the harness, loose the black (earth) and tape/tuck it away into the harness, then extend the +ve wire, tape it into the loom so its nice and neat and push it into pin 1 on the main headlight connector.
Users browsing this forum: Chug, Google Adsense [Bot], knobby1, Majestic-12 [Bot], Philio78
