Hi everyone first of all just want to say hi to everyone!
I have a 2003 2.0 diesel turbo transit - not had it long but it seems to be underpowered, used to have a 1.9 renault traffic which flew tbh but other than that a complete pile of crap so got rid and picked the transit up which im happy with as a workhorse and spacewise its great!
I can hear the turbo spooling but there seems to be no ooopmh not sure which horse power i have it just says t300 on the side is there a way to find out? My reg is yg03 yfb
I have inspected the pipes and all connections and cant see any loose / splits. I have also blanked my egr off but its the same.
I pulled a hose off the actuator to turbo and it still went the same so leading me to think turbo has gone or something along those lines.
Have a bit of knowledge turbo wise as i used to own a starlet turbo (glanza) swapped turbos etc so learnt a little about pipes vac pipes etc only a bit tho
Soooooo.... i might replace the turbo as its on 153.0000 now is it easy enough? And can you leave the manifold in place and just remove the turbo?
And will a turbo for a 100ps model bolt straight on? Might do that if i can
Can hear the turbo spool up but just lacks ooomph, as said when i disconnected the actuator hose it was still the same power.
It gets to about 60 odd 70 on motorway and stays there and then if there is a hill or incline it really starts slowing down and have to go into 4th 3rd gear
Thanks guys hopefully someone can help, cheers again - matt
Sent from my SM-G900F using Tapatalk
