Runaway engine, Mk7 2.2 FWD
Re: Runaway engine, Mk7 2.2 FWD
Postby Peregrine » Fri Jun 24, 2016 3:02 pm
Oh yes, no doubt they know how to charge. However, I don't have the time or facilities to change the lump over myself, so I am pretty much stuck :-(
Perry
2006 Mk 7 85 T260 (now transformed by Vantuner!), new turbo and recon engine
2001 Jaguar S Type 4.0 V8
1936 Morris 8 (engine rebuild in progress)
2015 Royal Enfield 500 Classic
Peregrine
Postby karl » Fri Jun 24, 2016 3:46 pm
Peregrine wrote:Oh yes, no doubt they know how to charge. However, I don't have the time or facilities to change the lump over myself, so I am pretty much stuck :-(
if you were closer id do it for you,but you miles away :(
and for half the price of what they are charging the cheeky twats
karl
Tranny Lover!!!
Postby pwhooftman » Fri Jun 24, 2016 8:20 pm
I'm curious: i'd reckon a runaway engine would ruin it's valvetrain or timing chain assembly or other auxilaries first, not the bottom end. Unless it's running away long enough to use up all oil, which doesn't seem logical if it only runs away for 3-4 seconds. Anyone care to explain how the bottom end gets f'd up?
Ford Transit Mk6 (2001) 2.4 Tddi 120 PS RWD twin wheel motorhome, tickled by Vantuner :D
pwhooftman
Postby davyjcb » Fri Jun 24, 2016 9:20 pm
The turbo like the big ends and mains run's on a film of oil,if the oil pressure was low all the white metal bearings suffer the same fate you can't see the damage the crank is suffering because the excess oil escapes back into the sump but when the turbo lets go the oil dumps into the induction /exhaust system which is very evident this could what happened a long slow decline
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby knobby1 » Sat Jun 25, 2016 5:33 am
pwhooftman wrote:I'm curious: i'd reckon a runaway engine would ruin it's valvetrain or timing chain assembly or other auxilaries first, not the bottom end. Unless it's running away long enough to use up all oil, which doesn't seem logical if it only runs away for 3-4 seconds. Anyone care to explain how the bottom end gets f'd up?
When the engine "runs away" on it's own oil....it will run flat out, there's no rev limiter like when you're driving it, the rods usually get kicked out the side of the block because they cant handle the extreme loads.. The engine doesn't usually run out of oil, it just runs flat knackers until something breaks....the weakest link is usually a rod or rod bearing....there's heluva lot of load and inertia happening in there.
Postby davyjcb » Sat Jun 25, 2016 8:17 am
The local tec did an experiment on this(motor vehicle Studies) an ran an engine with a tin of ether,same effect as blown turbo but it had good oil pressure and survived the instructor explained that con rods are designed to take most of their load vertically with some sideway movement the engine was then drained to a couple of pints just above the suction tube level and repeated 15 seconds did the job it threw a leg out of bed . oil starvation ,heat an the big ends bound up on the journals con rods cant take torque loading I think it was an old nova engine cant remember it was petrol but result would be similar
davyjcb
Postby andz327 » Sat Jun 25, 2016 10:59 am
Had a mk 6 2.0 do it, replaced the turbo, but van wouldn't start, had thought the worst but it was the fuel pump that had fooked up, second hand on and it ran perfect, think it's a bit to do with luck and a big bit of how quickly you realise what the fooks going on and stall the fooker
There's plenty supply and fit engine shops doing it for aboot £1200-£2000
What exactly are they saying is wrong with bottom end?? Have you heard or seen it yourself, the maybe think an injector knock is a knackered engine (they may not do transits much)
andz327
Postby Peregrine » Sun Jun 26, 2016 12:08 pm
I only have their word for it over the phone so far but I don't doubt their diagnosis. I'll be going to see for myself tomorrow and, in the meantime, I've found an outfit who will supply and fit a good recon engine for just under £2k. Perhaps all is not yet lost!
Perry
Peregrine
