11sparky40 wrote:Where to start?
So bought a MWB, RWD, 2.4 tddi mk6 transit with engine problem. Unbeknownst to me it was the 90hp version, I wasn't even aware at the time that different powered versions of the same engines existed. Ignorant I know. Anyhow.....
It came apparent another engine was required so my mechanic advised me if I was able to source one he would put it in (at this point I'd add that this guy is a superb mechanic but works primarily on coaches and is not necessarily up to speed on engine models of every van out there, I regard him as more than competent).
So off I go and within 24hrs I back with a 2.4 tddi, only problem is it's the 125hp.
So the engine goes in and his guy turns up to reprogram the pump to the ecu and the came the bad news, not the right engine. So now faced with the choice of get another engine or attempt to make it happen, we or more accurately I decide to give it a go. So off comes the vp44 and on goes the vp30 and whoosh, engine starts, idles and reeves up like a dream.
Now for the issue.......
So when driving through the gears, 5 speed gearbox, when we get to roughly 2500rpm we experience flat spots in the delivery of power and it may take until past 3500rpm until we resume normal power, then we change up to 2nd and maybe 3rd and the whole ordeal is repeated. Not nice!!!!! As a result I have to scream it though every gear and basically rag the arse out of it in order to get up to decent speeds. It not a problem around town cos when driving miss daisy serious power is not required however with any amount of weight on and on the A1 or any motorway if I have to slow down for any reason, usually a slower driver pulling across the lanes then it takes an age to regather any momentum.
We have tried the 90 hp injectors and we had some improvement by blanking the erg valve which we thought fixed the issue, but since then we put back the 125hp injectors and the issue came back.
So now I'm of the opinion that the whole set up needs to be 125hp and vp44 but the ecu needs to be remapped to suit.
How can I get this done? Is this even possible?
Thanks for your time.
11sparky40 wrote:What year is your van ?
11sparky40 wrote:martynx wrote: What year is your van ?
It's 2005
Only the early ones Never seen one on digi dash model .loot wrote:Doesn't the mk6 125ps also have the electronic fuel filter lift pump
bambi mk 1 wrote:The turbos are the same Glad you sorted it and thanks for giving the final verdict
